Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: mk3 bottom end for a mk1
    PERTH
    pls pls if you choose to go for the 8v bottom end, get the pistons cut down for the valves like someone said befor or get a spacer and another head gasket to raise the head a few mm
    hey vankronenburg whats the best choice pistons if you were to bore the 1.8 to 1.9 ?
    the golf is not dead.
    VanKronenburg Guest
    Quote Originally Posted by finemk1
    If you use a spacer, you only lower the compression further - why would he do this
    In terms of pistons, we like to use Mahle or JE; both will make any specification. 11.5:1 is the best street compression ratio for a mild tune 16v. It is both safe and provides a decent boost in mid range. It is possible to go right up to 13.5:1, but this requires modification to the block to set the head at an angle for valve clearance. Remember that the motor will run hotter if bored to 1.9 with higher compression: of course the compression boost creates more heat but there is also less space in the cylinder walls for this heat to be stored. A remote oil cooler is a good idea.
    PERTH
    If you use a spacer, you only lower the compression further - why would he do this Question
    was recomended to me after i had a boo boo, i think he was as smart as me at the time and just looking for answers........ ie. not very smart hey
    Golfwise Guest
    Fine it appears you used normal 8v pistons and the valves when open had no where to go but through them.Thats why 16v pistons are different You take too much notice of bad advice.
Similar Threads
  1. Bottom Skirt Clips for Mk1
    By barrygti in forum Mk1 Golf
    Last Post: 04-03-2007, 04:19 PM
  2. Aaaaarggghhh!!
    By mollins in forum Mk1 Golf
    Last Post: 25-02-2007, 08:33 PM
  3. Bottom End rebuild Advice
    By smithy010 in forum Mk1 Golf
    Last Post: 28-10-2006, 11:13 AM
  4. Torque setting for bottom end
    By 82cab in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-11-2005, 09:55 AM
