Results 1 to 10 of 19
Thread: Brake upgrade options
Schalke04 Brake upgrade options 24-12-2013, 04:33 PM
GOLFBALLS So are you running the 280mm... 25-12-2013, 03:04 AM
Schalke04 Yeah running the 280mm, I'm... 25-12-2013, 03:23 AM
Schalke04 Anyone have any ideas?? 26-12-2013, 12:24 AM
Peter Jones The 6 pot Tarox brakes are... 26-12-2013, 07:57 AM
Schalke04 They look to be good brakes,... 26-12-2013, 01:05 PM
Martin Tarox are fairly well priced... 26-12-2013, 11:12 PM
Watercooled Reckon a stock rebuilt mk3 4... 26-12-2013, 08:29 PM
ryana89 ^But he is running 2-3 times... 26-12-2013, 10:36 PM
Schalke04 There are many brembos on... 27-12-2013, 01:29 AM
Martin Ok Single piston calipers... 27-12-2013, 08:56 AM
Schalke04 Those hpa's look amazing! I... 28-12-2013, 02:29 AM
Martin It's the front calipers from... 03-01-2014, 05:01 PM
Schalke04 I'm pretty sure the boxster... 03-01-2014, 07:15 PM
Schalke04 Anyone have any other... 02-01-2014, 07:31 PM
Peter Jones Boxter rears might be a bit... 03-01-2014, 07:52 AM
Schalke04 The boxster rears are 4 pot,... 03-01-2014, 04:21 PM
GOLFBALLS Hold up. WHY? noone... 04-01-2014, 04:02 AM
Schalke04 Going to bring this thread... 25-09-2016, 01:59 AM
    Oct 2010
    Looking to upgrade my brakes sometime in the near future. Currently have the seat cupra brakes. I've seen a few options, willwood kit, seat Leon cupra r Brembos. Just trying to find the easiest and best option. I'd like to be able to keep my 15s but would also go 16s. Let me know your suggestions.
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
    Dec 2007
    Perth, WA. *YAWN*...
    So are you running the 280mm front disc setup?
    Why do you want to go bigger?
    I run the 280 discs with golf 3 GL front hubs and the VR6 callipers. Standard mk2 GTI rear. Just using Ate discs (the best) and EBC greenstuff pads.
    I've done a few track events with this setup under my 1.8T and found it was more than adequate. They were pushed pretty hard too....
    Cheers,
    Wade
    Oct 2010
    Quote Originally Posted by GOLFBALLS View Post
    Cheers,
    Wade
    Yeah running the 280mm, I'm thinking if going gt28 or something like that and I'd like to upgrade the brakes. Was thinking of trying to get some 4pot brembos and keep current disc size( would need to get adapters made). There are lots of brakes I can use but it's extremely hard to find them in aus, so I'm just trying to find out what people think is best and worthwhile .
    Golf mk2 GTi 8v
    Oct 2010
    Golf mk2 GTi 8v
    Oakleigh VIC
    The 6 pot Tarox brakes are working well for me.
    I'm running the 280mm disc inside 15" rims.
    (I've got them on a MK1, but it's using MK2 16v uprights.)
    I gave up on he stock style single and dual piston calipers as I kept getting pad knock off no matter what I tried. Now pedal feel is consistent through out a race.
    Just watch out for clearance on the back side of the wheel with any of the big brake kits. It can be hard to find wheels that will clear the calipers.
    Tarox | High Performance Brakes
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oct 2010
    They look to be good brakes, but are a little pricey. I was looking at trying to get a used set of brembos or something like the 944 turbo brakes. I hear they bolt up with a spacer for the brakes, not sure if you use front or rear brakes though... Willwoods seem pretty well priced, anyone know anything about them?
    Golf mk2 GTi 8v
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by Schalke04 View Post
    Willwood are the cheapest BBK kits out there (not by much) - not really sure why they are cheap - the only thing I've heard is they don't have dust seals (they are more for motorsport) and this can cause problems
    Have a look at the price of KSport/StopTech/Brembo (new) and then compare to Tarox
    Or buy 15 year old Brembo's (especially if they have been sitting at a wrecker for years) and after paying to powercoat, re-kit and tap out the bleed nipples (it can be a frustrating nightmare) and then compare to Tarox
    Oct 2013
    Tasman,Nelson ,New Zealand
    Reckon a stock rebuilt mk3 4 wheel disk setup will stop this car fine,if its all new or reconditoned it will do fine with good pads,these cars are pretty light afterall.
    1987 Golf GLI Wolfsburg Edition,full gti spec 3a Audi 2 litre on dijifant 2
    1989 Corrado 1.8 16v KR manual (02a) black 15x7 RH cups
    1987 Golf GTI original 3 owner in white.
    Audi Quattro,and various Porsches
    May 2010
    NQ
    ^But he is running 2-3 times more power than a stock MK2....
    Like this thread, cool info.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Oct 2010
    There are many brembos on newer small cars that would be running discs around the same size... Wouldn't have to be super old, or I could buy a reconditioned set. The reason I want to go different brakes is the single piston doesn't seem to work as good as I'd like it to. 4 pots apply the pressure even and that should make for much better braking. I may look around and try find a set of brembos and get a brake carrier made. Just trying to find out if anyone knows of any that could fit easy.
    Golf mk2 GTi 8v
