Hi,
Can anyone point me in the right direction?
Is there anyone who does the conversion?
Thanks,
Nick
There's tonnes of information on vortex and European forums. Best to search there.
I used to own one.
Used corrado front crossmember to utilze mk3 front mounts. (Can get mk2 to mk3 solid mounts off ebay nowadays.
If you have a ce2 mk2 the wiring is plug and play except for the tach signal which you will get from the coilpack harness.
Easiest to swap full front subframe of a mk3 into the mk2. You gain ~2mm extra track, vr6 brakes etc.
