Results 1 to 10 of 19
Thread: mk2 swimming pool
    mk2 swimming pool
    hey guys i went out today to find my mk2 with a swimming pool in the rear pass floor and a wet pass floor lol , i guess ill now have to find where the water is getting in. where do most of you guys find the water entering the car??
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    door seals.
    my old mk2 tour used to like like a bitch!
    ended up taking up the carpets cos i didnt change the seals lol
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Sep 2006
    Banff, Canada
    Yep, front door seals (well, having said that, I only have front doors), I find they tend to leak around the bottom rear of the door in heavy rain, from my experience.
    Canadian dubs coming to VWwA soon
    Jun 2006
    Hornsby
    I told you! I had the same thing mate so im going hard core, had enough im getting some super sealent **** from the states, also you know the clips that you screw the door card onto?, they leak at the bottom thus allowing heaps of water in, its a small hole but man it crazy
    Suffolk UK
    The last Mk 2 i had used to puddle in the rear passenger foot well. I found it to be (and its quite common) the membrane behind the door driver door card, the water used to run down into the window slot, then come out of the bottom of the door card, then get under the carpet because the membrane was rotten and had holes in it.
    It happpens to Corrado's as well.
    Camden, Sydney
    You could just make a hole in the floor to let the water back out
    wow loon i could have guessed thats what you would say haha, but then when i drive in the wet it will come up thru the floor. its in the shed now with the carpets out. hose time this weekend to find out which spot its coming from. as the drivers side didnt leak at all . just pass side
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Camden, Sydney
    Mk2 seals are expensive and a hole in the floor is free. I thought that would appeal to you boys in the Oaks ghetto
    Besides if water comes up throught the hole in the wet, it`ll drain back out when you stop.
    Apr 2006
    Ashfield NSW
    haha "holes are for free"- its hard to argue with the loon logic
    Feb 2008
    What about doing the floor drilling, but adding a small one way valve to the hole??
