Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: mk2 swimming pool
    Camden, Sydney
    Quote Originally Posted by Blitzen View Post
    What about doing the floor drilling, but adding a small one way valve to the hole??
    Or just drill a hole in one of the rubber bungs in the floor. Or pull the bung out.
    Jul 2007
    Earlwood Sydney
    Drilling holes is fun, and it makes your car lighter!
    yeah ill get in the car and get my brother to hose the car down and ill see if i can find the problem spot.
    Holes are free lol thats true but the less the better.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Jun 2006
    Thornbury, Vic
    This happens to me as well, drivers side rear floor. So there's no way of quick fixing this problem besides drilling a hole in the floor?
    Camden, Sydney
    Quote Originally Posted by Satanstoenail View Post
    To fix it you need new door seals which are expensive and hard to get in Australia.
    For the quick cheap fix, get your drill out
    I reckon a small drilled hole is better than a saturated floor that has fully rusted out.
    Jun 2006
    Thornbury, Vic
    Wouldn't a hole drilled through the floor lead to rust anyway?
    Jun 2007
    Eastern Suburbs Melbourne
    not if it's properly rust protected.
    if you just drill it and leave the bare metal there, then yea, it'll rust.
    a rubber bung of sorts might help too.
    i like volkswagens
    May 2006
    Quote Originally Posted by carpoid View Post
    ... the membrane behind the door driver door card, the water used to run down into the window slot, then come out of the bottom of the door card, then get under the carpet because the membrane was rotten and had holes in it.
    The membrane door liner must be intact and glued to the door all the way round each door. The membrane is usually broken if the central locking is repaired, or the window winder is repaired or the door itself is repaired.
    Make sure there's no water on the front floors too. From the front floors, water can make its way to the back floors. If there's water in the front too, then that's almost certainly how you're getting water in the back. Water in the front could come from a leaking heater matrix, leaking heater hose, leaking air boxes.
    and even no plastic cover on the rain tray then down into the heater and onto the floor . you really have to catch the water in the act, but drilling a hole in the floor doesnt fix the problem lol then you will just get a river instead of a pool. but everthing still gets wet when the water comes in.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
