Confirms the problem is with the starter or battery not charging properly.
Next time it happens at night turn on the headlights and see if they go dim when you try to start the car on the starter motor. If they do then either you've got a dying battery, alternator not charging properly or poor earth lead connections between battery, body and engine.
If the lights stay bright you've got a faulty starter motor.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
