Results 1 to 7 of 7
Thread: mk2 problems :( need help
    Jun 2014
    I took my mk2 gti for a Sunday drive when all of a sudden it turns off, and it wont turn back on. When I turn the car key, a ticking/spinning noise come from under the car near the fuel tank. It wont stop ticking it turns on for a split second and it dies again. Any ideas???
    Jul 2009
    Geelong, Victoria
    starter motor thrust bearing could be stuck
    or a dead battery can cause all sorts of electrical gremlins - if you can measure your battery voltage and it is below 12v at rest there could well be a problem, even if other electrical stuff seems to work ok
    check also the main cables to and from the battery, making sure they are clean and well attached - one will go to your starter , check that especially
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Does the starter motor make any noise? Clicking when you turn the key all the way?
    Can you push start?
    Judging by his mention of it "all of a sudden" turning off and noise coming from the fuel pump, i would guess perhaps an issue with the fuel filter perhaps being clogged? or the pump malfunctioning?
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
    Jul 2009
    Geelong, Victoria
    yes possible, but a battery will do this as well, but you would still get cranking with a dead fuel pump
    Jun 2014
    All sorted thanks for the feedback guys. Replaced the battery and fuel filter.
    That's exactly what I was going to suggest.
    Honest.
    Well maybe.
    Perhaps.
    I could have, on a good day.
