Whats the diameter of the pod filter for starters?
Purchased a pod filter from autobarn for my mk2, i need some installation advice....
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
If it is a digifant car you will need an adaptor plate as the air flow meter is square and the pod will be round. You will also need a bracket the hold the air flow meter. I have some pics of the kits I have, I don't have it on the car anymore so may sell it if you need it.
cheers,
Here Is The Info:
I Bought The Adaptor Plate, Bracket And The Air Flow Meter, Should I Watch Out For Anything, I Am Worried Is It Really Going To Decrease Power ...
where can i get the heat shield?
bit late but everything u need is at autobarn and i dont recommend a poddy anyway. You can make a heat shield urself. Use cardboard for making the template and then cut it from sheet metal.
Ive got a used K&N panel filter, it neads a clean and re-oil but a drilled box with a K&N is better than a poddy.
MK1 GLS 3door
A4 B7 2.0T
for mk2 ghetto mods, swiss cheese the non engine side of your air box and put and k&n filter in your airbox. no hassle, lovely noise, no realistic chance of catching fire (legalities...).
87' MK2 GTI
13' MK7 TDI
