Results 1 to 9 of 9
Thread: mk2 pod filter install
    Jun 2008
    gold coast
    Purchased a pod filter from autobarn for my mk2, i need some installation advice....
    Jan 2007
    Whats the diameter of the pod filter for starters?
    Penrith, NSW
    Quote Originally Posted by salem1 View Post
    I know you have already bought it, but you would have been better off keeping your air box. You may find power will be down after the mod...
    Anyway..like Mr Houso said...a little more info would be good. diameter? what did you get in the kit as far as brackets etc?
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Oct 2005
    Nowra, NSW
    If it is a digifant car you will need an adaptor plate as the air flow meter is square and the pod will be round. You will also need a bracket the hold the air flow meter. I have some pics of the kits I have, I don't have it on the car anymore so may sell it if you need it.
    cheers,
    Jun 2008
    gold coast
    Here Is The Info:
    I Bought The Adaptor Plate, Bracket And The Air Flow Meter, Should I Watch Out For Anything, I Am Worried Is It Really Going To Decrease Power ...
    Jan 2007
    Here Is The Info:
    Heat Shield
    Jun 2008
    gold coast
    where can i get the heat shield?
    Feb 2007
    bit late but everything u need is at autobarn and i dont recommend a poddy anyway. You can make a heat shield urself. Use cardboard for making the template and then cut it from sheet metal.
    Ive got a used K&N panel filter, it neads a clean and re-oil but a drilled box with a K&N is better than a poddy.
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2007
    for mk2 ghetto mods, swiss cheese the non engine side of your air box and put and k&n filter in your airbox. no hassle, lovely noise, no realistic chance of catching fire (legalities... ).
    87' MK2 GTI
    13' MK7 TDI
