Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 52
Thread: mk2 jetta coupe...the irish one.
  1. #31
    Aug 2012
    ireland
    so heres a few more pics of where this is going now
    trial fit to see what has to go where..
  2. #32
    Aug 2012
    ireland
    did a bit of a refurb on the block and the rockercover
    just mocking things up before the final fit.just gave everything a bit of a freshen up with all new gaskets and seals,water pump and all that poop.
  3. #33
    Aug 2012
    ireland
    So this is where i am at as of today,3/8/2012 out of its rest place and a bit of a wash and into its new home for a bit more room for work.
    full boot carpet which is due a good clean
    i originally got a washer bottle from an opel combo van as its small and can mount it almost anywhere
    but in the meantime i found an early 85 golf with one of these.
    ive been trying to find one for ages!!
    rear screen washer bottle B-) ,with motor,you can see the motor on the opel bottle
    and whats better is its a direct fit into the jetta boot!
    i also have a mk5 battery box going into the boot on the other side.
    i will be taking out the front subframe now during the week and other various bits and pieces to get powder coated,including all the motor mounts,rad support and the modified alt and powersteering brackets and mk4 powersteering pump.
    lookslike its going to start to look like a car again very soon.
    sorry bout the poop pic,the lense on my camera is cracked,also got a rear spoiler.....which im in two minds about now?
  4. #34
    Aug 2012
    ireland
    started again at this today,removing the subframe,wishbones,rack etc..
    a few more bits to get powdercoated.
    pulled off the wing to get the rest of the welding done in the battery tray
    got these a while ago to fill a few holes
    and give these a freshen up also
    its also getting new bushings all round for the whole front end.
    thats how it sits tonight,8/8/2012gona try keep at this now that i have a bit of room to mess about with.
  5. #35
    Aug 2012
    ireland
    so here we are bang up to date as of tonight,9/8/2012
    drilled out the rest of the old one.
    hopefully have this welded up over the weekend.
    also gona stick in a powersteering res from a mk4 into the inner wing somewhere here and just have the cap sticking through the battery tray.just have to make the hole a little bit wider.
    and going to take off the clamp for the battery while im at it.
    you can see here that the copy part isnt an exact match but its going to work out though
    once the tray is in,im going to start to remove all the sealer in the bay,not really looking foreward to that but its gota be done!
    so any comments,good or bad please feel free to add em,i would be interested in youre input as im going along to give me some ideas!
    more pics over the weekend!!
  6. #36
    Aug 2012
    ireland
    picked up a few other bits for this
    brand new rear hella tails!
    and miltec 4 to 1 manifold.
    im sure you all seen an engine been stripped before, il not bore ya..
    im going to lower the altenator because the carbs will hit.
    so im using a mk3 2.o 8v alt and an abf bracket for it,along with the auto adjust spring setup and ribbed belt
    a seat inca 1.9 1y crank pulley and waterpump pulley.i just have to get another powersteering pulley fitted,i have a few here with different offsets
    its all just trial fit at the monent,the abf bracket has to be modified a bit ,has to be shaved in a few spots but its going in the right direction.
  7. #37
    you aren't mucking around are ya mate! Keep the updates coming
  8. #38
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by vinnie View Post
    Any links to where this manifold came from? Or home built?
  9. #39
    Nov 2007
    Yallambie
    awesome full steam ahead
    500 Series Hino - 99 V6 PASSAT Daily Driver
    84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
  10. #40
    Aug 2012
    ireland
    Quote Originally Posted by GoLfMan View Post
    Quote Originally Posted by Water Boy View Post
    Quote Originally Posted by moostin View Post
    cheers for the positive words lads!!!
    @ waterboy..
    heres a link to the site,i had it custom made by these lads,it cost about 350 euro from what i can remember
    and about a 4 week waiting time but its well worh the money and the headache to make my own.
    heres another pic of mine!
    Bogg Brothers fabrication
