cool, keep em coming!
more laters..plenty more pics!
Quite enjoying this thread!
Awesome Jetta dude!
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Stunning looking Jetta,and I am so pleased it has the Jetta front again,as it looked wrong with the Golf headlights...
Damn it the wish list just got longer
So that's an
MK4 R32
MK1 Caddy
MK2 Rallye
R36
12' R
V10 Touareg
and now a Jetta Coupe
Damn Damn Damn
By the way it looks great!
500 Series Hino - 99 V6 PASSAT Daily Driver
84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
removed the exhaust manni and gear linkage,fusebox,getting the chassis legs ready for welding up holes etc,gona start at the passanger side tommorrow and remove the loom from the leg and get the battery tray cut out..also trial fitted the cable shifter to see how things look there too.gona remove the subframe to and get it blasted and powercoated along with the steering rack.
so a bit more done today,got the pedal box finished off,rewelded on the bracket that bolts to the under side of the dash rail,i used to bracket from the old cable pedal box.
tapped out the clutch master cylinder so i could bolt it up from the inside..just have to shorten up the bolts a small bit..
finished off the welding on the bulkhead,just need a skim of filler when the rest of the engine bay is finished off doing the welding up.
soome complete boot carpet i got from a jetta in the scrappie ages ago...and new rear lights on the way also..
got these the other day,full set of locks and keys,fairly cheep to,have to do a bit of changing round and get some other keys cut.
im relocating the battery to the boot and the original tray way in shyte so it had to go,
ive been putting this off for ages.
the only replacement tray i could get was from one of the mates who wasnt using it anymore as the genuine one cant be had anywhere
i had to cut out the old loom first which is going to be routed through the leg later on.
its not the best fitment but ill tidy it up alot better when the rest of the bay is being done.
