Yes Spike we did, found out something was wrong inside the head....basically Number 3 cylinder was leaking and the ECU was full of water (drain holes in tray was blocked)
So fitted a new ECU and changing the engine.
Do a leak test...make sure all the valves are closing
Much appreciated, gives me a starting point now. Thanks mate.
Geez sounds serious Velly, all sorted now ? was it just the ECU in the end?
I changed the ECU and it started to fire...but then just wouldnt start.
Changed the engine and all was good.
I have the old engine while I was to pull apart to find the problem. Plus the old engine was a 2.0 with high lift cam.
So I want to take it apart and sell the bottom end and the cam.
Keep us Posted Spike
Pulled out the ecu today and pulled it down, everything looks ok.
http://i817.photobucket.com/albums/z...ps7e5840d4.jpg
I wouldn't mind getting another to just test the theory. Any one got a spare that they want to sell?
http://i817.photobucket.com/albums/z...ps2bf954b6.jpg
my ECU was full of rusty water!
