Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
Thread: MK2 GTi RV rece build
    Jun 2007
    Eastern Suburbs Melbourne
    sounds all pretty good matey.
    Would be fun to see it all up and running!
    i like volkswagens
    Aug 2006
    Melbourne VIC
    Can u get some cool VW stickers ent over the bits n pieces?
    Any 15x7 wheels in 4x100 stud patterns around et25-27
    Jan 2008
    stickers? yeah sure i can get em here within a couple of days or the week.
    ill send pics of some stickers. anything inpaticular?
    or even badges etc.
    Nov 2005
    Why would you fit rs2 pistons in an 8v? RS2 is 4v/cylinder.
    Jan 2007
    Quote Originally Posted by WABIT View Post
    He wants to supercharge it...
    Nov 2005
    Those rear brakes are a bit overkill too on the back end of a car that basically does nothing. The front brakes on a 16v which you can get 170bhp from pretty easily are 256mm.
    Goodluck with the project though. Love the mk2's.
    PS. It's ausgolfer writting on doms id.
    Nov 2005
    Quote Originally Posted by Golf Houso View Post
    valve angles on a 16v piston are not compatible with an 8v
    Jan 2008
    well this engine is built to last.
    alot of tuners use this setup for turbo or hardcore tuning. can go up to 500hp
    in which case you will need alot of brake power
    also more area to stop on means less heat than on small breaks
    Nov 2005
    Quote Originally Posted by jeanheide View Post
    ok.......... but it still doesnt explain how 16v pistons can work on an 8v head, especially on one that you want a compression ratio of 11.5:1............ and then supercharge it
    Jan 2008
    ok, well the head is being ported reworked etc to 11.5:1
    but this is just non aspirated engine.
    once it gets a supercharger i am making myself a new head and then making compression 8.5:1 or the standard 8:1
    as much as i know the rs2 do work in the 8v.
    i think they are a bit lower than the 8v in height so they should be able to fit
    just checking it out.
