Have you got power at the coil?
Howdy all,
I’m having some dramas starting my mk2 gti 8v. I’m not getting a spark, I’ve recently replaced the distributor, ignition coil and also the ignition module and still no joy...any tips??
Cheers,
Rob.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Yeah I have power to the coil. Just realised I can’t hear the fuel pump when accessories are on so a blown pump be an option?
Check fuses first and that power is getting to the fuse. The fuse cover shows which fuse looks after the pump.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Thanks mate, problem solved, turned out to be a blown relay for the fuel pump.
