Results 1 to 5 of 5
Thread: Mk2 gti ignition issue
    Jan 2018
    Howdy all,
    I’m having some dramas starting my mk2 gti 8v. I’m not getting a spark, I’ve recently replaced the distributor, ignition coil and also the ignition module and still no joy...any tips??
    Cheers,
    Rob.
    Jul 2005
    Have you got power at the coil?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jan 2018
    Yeah I have power to the coil. Just realised I can’t hear the fuel pump when accessories are on so a blown pump be an option?
    Check fuses first and that power is getting to the fuse. The fuse cover shows which fuse looks after the pump.
    Jan 2018
    Thanks mate, problem solved, turned out to be a blown relay for the fuel pump.
