Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: mk2 gti first day dramas
    Dec 2008
    Perth
    Hey all bought myself a mk2 this morning, she needed a few things but was cheap enough to take a bargain on so i picked her up, got half way down the kwinana freeway and she starts smoking up and spewing out water... turns out one of the pipes just under the oil cooler has blown and its dropped all its water....
    managed to bypass the oil cooler and get some water back into it but there was an awful tappet noise and the idles very out, and she heated up again on the way back. managed to crawl it back to a mates place where its cooling down and ill see waht its like in the morning.
    probability that its blown the head gasket??
    Nov 2005
    hey mate,
    check the oilcap to see if the water has gone into the head, if the oil is milky-ish then a headgasket it will be!
    dom
    Jan 2008
    Melbun
    think of it as a blessing in disguise, mk2's are great fun to work on
    2x Caddy, 1x Ducato
    Dec 2008
    Perth
    Quote Originally Posted by WABIT View Post
    hey mate,
    dom
    cheers will check that when i get it back this afternoon, would a compression test show anything up also?
    how big a job is the head gasket on these, might be easier to source another motor if its gone?
    Nov 2005
    as i say with every new v dubber....
    congratulations you are now officially broke!
    dom
    Dec 2008
    Perth
    one happy chappy:)
    went to pick her up today and she drove back fine, engine was running a little rough and the temperature was gradualy working its way up, but no major engine noises or problems. found out when i got back the fan hasnt been working as the fuse was blown so that explains the temperature.
    I think i'll take it down to wade during the week and just get him to check it over as its idling a bit low still and i want to get the suspension checked out so ill see what they think
    Feb 2009
    Please Enter Location
    just focus on what's broken then wait, she'll let you know what needs fixin
    May 2006
    Mk2 failures are usually very little things pretending to be big things. Mk 2 overheating can also be caused by the thermo fan switch at the bottom near side of the radiator. The switch itself can fail but more usually it is the connections on the switch that fail. The battery is just above the switch and acid vapour floats down to corrode the wires at the switch connection. It can save a lot of heatache to inspect them from time to time and repair if necessary.
    Dec 2008
    Perth
    cheers moto the gaskets definately gone as the oil started getting milky and its over heating fairly quickly so its booked in to be done next week, but i will have to check out that fan wiring as it still wouldnt come on, and i tested the fan and it was fine so yeah ill check it over. any subtle head mods i should consider while theyve got the head off? preferably nothing too heavy on the wallet
    the gasket is easy to change.
    mk2 gti's are so much fun to drive, i have a photo somewhere of a mk2 gti off the speedo and we was 4 up in her
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
