The part number you gave me matched against a digi I and I have a digi II
I also didn't say anything about being "jap spec"????
Thanks for your help and sorry for wasting your time.
Sent from my HTC Velocity 4G using Tapatalk 2
Not true, the part number you gave me was not the same, as you said yours is a jap spec ecu.
The one I have came from an Aussie delivered Mk2 and I know it works and give you warranty.
No-one can give you warranty against diagnosis, change the broken part and car works, keep changing expensive bits till car works and that can get expensive.
Good Luck
Got the replacement ECU from an Aus delivered MK2, ecu codes match "Golf Syncro" which was a 1.8 8v making 72kw, not the 82kw the international made which makes sense with what people saying about the aus delivered golfs were restricted (why....)
So yeah, looks like that may have been part of the problem (wrong ecu). Fingers crossed hey.
Good luck...
Here is a question.. i've seen ECU's with different letters at the end of the codes ..for example 037 906 022 M, 037 906 022 DB etc etc.... What do the letters at the end mean?
Thanks
Fonz
Last letter can be the kicker with most parts, especially if the org doesnt have one, but with some with say an L at the end may take the supercede version of M if that makes sense, but in general its important
Jmac
Alba European
Should be fine unless this particular golf happens to be a South African import... not sure why anyone would go through the effort of importing a 4 door 8 valver though?
In this case the letter at the end means the difference between a detuned golf syncro and a regular euro gti 8v
Everything I have read up on suggests that the AU delivered model had a tune similar to the california emissions restricted models.
All very confusing and all very German.
It tried to start, got a little vroom out of it then it stopped again. Checked the firing order.... mechanic that first looked at it must have read the 16v firing order as it was set up to be running anti clockwise, 8v is meant to be clockwise.
Fixed that, still no go. Sad kitteh. Going to change the rotor arm, and if that doesn't help it will go to a mechanic who hopefully knows something about these buckets.
Fuel flooding problem has disappeared though, so that's something...
This car has so far cost me $4,200 and I've gotten about 2 months and 1,000km of driving out of it. Deal of the century.
Any luck?
8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
Any news?... Would love to know the outcome
Sent from my iPad using Tapatalk HD
