Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: MK2 GTI filling the intake manifold with petrol
  1. #51
    Camden, Sydney
    Not true, the part number you gave me was not the same, as you said yours is a jap spec ecu.
    The one I have came from an Aussie delivered Mk2 and I know it works and give you warranty.
    No-one can give you warranty against diagnosis, change the broken part and car works, keep changing expensive bits till car works and that can get expensive.
    Good Luck
  2. #52
    Jan 2013
    Re: MK2 GTI filling the intake manifold with petrol
    The part number you gave me matched against a digi I and I have a digi II
    I also didn't say anything about being "jap spec"????
    Thanks for your help and sorry for wasting your time.
    Sent from my HTC Velocity 4G using Tapatalk 2
  3. #53
    Jan 2013
    Got the replacement ECU from an Aus delivered MK2, ecu codes match "Golf Syncro" which was a 1.8 8v making 72kw, not the 82kw the international made which makes sense with what people saying about the aus delivered golfs were restricted (why....)
    So yeah, looks like that may have been part of the problem (wrong ecu). Fingers crossed hey.
  4. #54
    Jan 2013
    Clayton, Vic
    Good luck...
    Here is a question.. i've seen ECU's with different letters at the end of the codes ..for example 037 906 022 M, 037 906 022 DB etc etc.... What do the letters at the end mean?
    Thanks
    Fonz
  5. #55
    Aug 2007
    Last letter can be the kicker with most parts, especially if the org doesnt have one, but with some with say an L at the end may take the supercede version of M if that makes sense, but in general its important
    Jmac
    Alba European
  6. #56
    Jan 2013
    Should be fine unless this particular golf happens to be a South African import... not sure why anyone would go through the effort of importing a 4 door 8 valver though?
    In this case the letter at the end means the difference between a detuned golf syncro and a regular euro gti 8v
    Everything I have read up on suggests that the AU delivered model had a tune similar to the california emissions restricted models.
    All very confusing and all very German.
  7. #57
    Jan 2013
    It tried to start, got a little vroom out of it then it stopped again. Checked the firing order.... mechanic that first looked at it must have read the 16v firing order as it was set up to be running anti clockwise, 8v is meant to be clockwise.
    Fixed that, still no go. Sad kitteh. Going to change the rotor arm, and if that doesn't help it will go to a mechanic who hopefully knows something about these buckets.
    Fuel flooding problem has disappeared though, so that's something...
    This car has so far cost me $4,200 and I've gotten about 2 months and 1,000km of driving out of it. Deal of the century.
  8. #58
    Any luck?
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
  9. #59
    keep us posted
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  10. #60
    Jan 2013
    Clayton, Vic
    Any news?... Would love to know the outcome
    Sent from my iPad using Tapatalk HD
