Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: MK2 GTI filling the intake manifold with petrol
    Jan 2013
    Clayton, Vic
    There should be another from the engine block ( rocker cover) to the body as well
    Sent from my iPad using Tapatalk HD
    Jan 2013
    Quote Originally Posted by The Fonz View Post
    Yep, looks fine. Solid on both ends of the wire/cable. I also checked the relay for the ECU, looks brand new. I'm running out of "easy" options
    edit: just noticed some dodgey looking wiring to the right in that photo. Hmmm.
    Inline crimp to fix that busted looking wire.
    You can't say a connection is good by looking at it. Ideally you need to check the resistance of it with a multi meter.
    The braided line with no cover leaving your earth clamp goes to the stud on the chassis rail. Then it should go to the engine mount from there. This section is covered with plastic.
    Aug 2007
    Ill alter that slightly, you dont check for bad earth with resistance, you check it as a voltage drop and use Volts on your multimeter, with resistance all you are doing os checking the cable not the connection, check between the block and the cable, any more than 0.2 v is a bad earth, same as when checking a bad connection for your starter, if you use a jumper lead straight to battery and it starts better then it s a bad earth.
    Jmac
    Alba European
    you should really be using those star type of washers which improve current. forgot the name...
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
    Jan 2013
    Clayton, Vic
    Both Gavin and Jmac methods are correct... the resistance method is a quick way to check the continuity of the connection, if you find an issue, Jmac method will pin point it
    I would remake all the earth connections...clean any ingress and crap you might find and clean up all the loose wiring in the engine bay making sure that some frayed wire isn't earthed, just to be certain and you would be glad you did it. Failing that, I would most likely say that the issue is with the ECU.... did you get hold of the other ECU you mentioned earlier?
    Jan 2013
    Re: MK2 GTI filling the intake manifold with petrol
    Not yet, I will be grabbing it during the week.
    Sent from my HTC Velocity 4G using Tapatalk 2
    Jan 2013
    Jan 2013
    Clayton, Vic
    In picture 2 where you have the probe on the rocker cover ( .05V )... just remember it has paint there and will stop the proper connection being made... it should be bare metal connections.. thats whey you get the proper volt reading in Picture 1
    From this you can say that the Engine block is correctly earthed but a little bit baffled by the last pic... is that an earth wire??? where does it go too??
    What you have to remember is that its the ECU that controls the fuel Injectors to open or close and anything in between... different input signals from around the car inform the ECU on the ratio of fuel to come out of the injector.. i.e the Co2 sensor informs the ECU if the amount of fuel being delivered is to lean or rich... the Airflow Sensor informs the ECU how much and type of Air is coming into the engine etc etc (there are a few)... The ECU then makes its calculations and adjusts the fuel deliver to match
    It could be and earthing issue as that sometimes corrupts the signals getting to the ECU or it could be one of the input signals that has gone haywire... Trying a ECU that is known to be in good working order will eliminate a lot of the heartache in finding the problem.. you will then know if its the ECU or one of its inputs
    Hope that makes sense
    Fonz
    Jan 2013
    Cheers Fonz, I'll re check the rocker cover on a part where the paint has flaked off.
    For it to be over fueling before the engine is even started I wouldn't think it would be the air flow or o2 sensors acting up as they shouldn't come in to the equation until the motor is running right? I'll pick up that ECU and give it a go. Fingers crossed.
    Is there any possibility that it could be the digifant relay in the cabin acting up?
