Originally Posted by
Tim
mandrel bent is supposed to flow better cos when they are bent the pipes inner diameter doesnt change. The standard type of bend causes the pipe to get partially crushed which may lead to restriction or interfere with exhaust gas flow.
Head to youtube and type in mandrel bender and you will see how the process works.
This is correct, normal pipe bending produces a "kink" in the pipe, mandrel bending allows the tube to keeps it circular shape.
I would be interested if this really matters as once the gasses have reached this point would it really be restricting outlet flow ?
I am sure polishing and porting the outlet manifold of the head would and does make a great difference but unsure if spending the extra money on mandrel bent manifolds is worthwhile.( as you already have extractors )..without doing the former polish and port first..
1993 MK1 CAB ! Work in Progress........
