Results 1 to 6 of 6
Thread: mk2 Gti 8v - hydraulic or shim adjustable how to tell
    Mar 2007
    QLD
    Hi there all,
    I am wondering if there is any way to identify (without disassembly) what type of buckets are in the head of an 8v 92 GTI whether they are shim or hydraulic adjustment.
    My GF's gti is very "tappetty" and if they are shims then it is easily explained if not then maybe more major, engine has done over 320K km and trying to prepare for a rebuild before stripping it down.
    Thanks for any suggestions.
    Oakleigh VIC
    pull the rocker cover off. It's easy to spot the shims on top of the lifters if it's solid.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Dec 2009
    Fitzroy, VIC
    Pete's right, not much work required to take the cover off!
    Also worth checking the manifold gaskets, if they're cactus the leak can transfer the noise from the head..
    Jun 2006
    Orange NSW
    Once you have the rocker cover off the easiest way to see is that no.4 camshaft retainer cap is missing and an oil skirter is in underneath the cam which indicates its a hydraulic head.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Feb 2007
    Aren't all mk2s hydraulic especially 90s?
    Very common problem, usually fixed by replacing the bastards, last time i bought them from GAP they cost me $85.
    MK1 GLS 3door
    A4 B7 2.0T
    Quote Originally Posted by Spyda View Post
    Assuming the oil pump pickup isn't partially blocked with debris.
