Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: MK2 GTi
    Oct 2011
    Kensington
    PM sent to your inbox
    Lewi - 1986 Mk2 GTI
    ABF 2.0L 16v
    @ AusScare, sorry i dont have the shell any more.
    so you still have the ECU?
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    no sorry, dont have ecu anymore
    ---------- Post added 20-12-2011 at 10:02 AM ---------- Previous post was 19-12-2011 at 08:07 PM ----------
    Prices
    -sachs clutch plate $50
    -2x 8v cams, one stock the other a 272deg cam ; stock $40, 272deg $180
    -oil pump $30
    -alternator $50, aircon unit $50, starter motor $50
    -radiator setup incl aircon cooler and fan with covers $60
    -gloss black powder coated intake manifold (never used since poweder coating) $100
    -Dizzy Setup with spark leads $20
    -PF engine head, ported and polished on the intake, got cleaned and had valves, springs and tappets replaced
    -full set of door seals all 4 doors (no cracks or tears) $200
    -Smoked rear lights $60 and front bumper blinkers $40 (original vw parts, right rear light has a crack on it but can be fixed)
    -front lights, (clear glass)$50
    -Eaton M45 supercharger (done 15k Miles from minicooper) perfect condition, clean and smooth turning and no leaks $300
    -front slam panel $100 and the red lined GTi grille with fog lights $100
    an entire mk2 engine and gearbox $500
    -perfect condition Dashboard $100
    -1.8l block in mint condition +0.01mm wear on every cylinder $100
    -crank $40
    -gearbox housing cleaned, degreased, sandblasted and powdercoated in gloss black with chrome vanadium bolts. $280
    clutch plate, alternator, dash and starter sold!
    Oct 2011
    Hey mate, was wondering if you still had the dash and the grille? cheers.
    James
    ---------- Post added at 04:47 PM ---------- Previous post was at 01:45 AM ----------
    Apologies had a look at previous post where it says dash sold. my bad. How about the grille
    Nov 2007
    Yallambie
    Quote Originally Posted by jamesdavid View Post
    James
    Hi Bronx1987
    Do you still have the following parts
    including brackets etc for both the a/c and the M45 charger?
    aircon unit $50
    Regards
    Austin
    500 Series Hino - 99 V6 PASSAT Daily Driver
    84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
