first of all welcome.
secon of all, how much power are you after? a noticeable increase or massive power gains?
Hey,
I am hoping to boost the power of my GTI in the cheapest and most effective way possible.
Can anyone suggest a few mods that help?
Car is stock, bar an exhaust system and bigger airfilter.
Alex
Just a noticable increase...nothing to major
Ive got a K&N filter on at the moment and I have been offered a chipped computer for a couple of hundred dollars, but I wondering if there are any other alternatives that are a little cheaper.
Drilled airbox and manifold sound relatively cheap but are they easy to do myself?
Drilled airbox can be done with a holesaw. Pretty damn easy. Velly or someone or similar 16v experience should be able to get you some pics.
The manifold is a straight swap as far as i know, so aslong as you put a new gasket on or don't damage the old one you should be ok.
200 bucks for a computer sounds reasonable.
Remember, dude, unless you can make everything yourself and do ALL the work, you've gotta pay to play.![]()
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
short term
fuel pump fuel filter
plugs leads
longterm
cam
adjust cam gear
lighten flywheel
aftermarket fuel comp
turbo
sky is the limit $$$$
ive got a spare 50mm intake and gaskets if u wanna get it.![]()
Kjet is mechanical injection, i cant see how you'd chip it either?
