Hey all, does anyone know the valve clearances for the Mk2 GTi 8v Kjet?
76' 2dr Kjet
ill check it out in a sec, but where did u get a kjet from? import? if so, what year model?
Golf MK2 Project
Daily car: Audi 90 2.3L 5cyl manual
"I run everything under pressure, from my supercharger to my blood"
What engine code is it?, most of them have hydraulic lifters.
Ok, cam shaft out and it's got hydraulic tappets/lifters. Thanks anyway loon & jean.
I'm continuing on to clean the tappets and hopefully unblock oil galley holes..
I'll let you know how it goes![]()
76' 2dr Kjet
A late reply, but a reply non the less!
I ended up taking the sump off to check the oil screen (which was fine).
Flushing the engine (which didn't fix it).
To eventually figure out that it was an exhaust leak (gasket on back to front)!
This is covered further in another thread:
http://www.vwwatercooled.org.au/newf...g+noise&page=3
76' 2dr Kjet
