Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: MK2 GTI 16v Upgrades
    Hey,
    I am hoping to boost the power of my GTI in the cheapest and most effective way possible.
    Can anyone suggest a few mods that help?
    Car is stock, bar an exhaust system and bigger airfilter.
    Alex
    Jun 2007
    Eastern Suburbs Melbourne
    first of all welcome.
    secon of all, how much power are you after? a noticeable increase or massive power gains?
    i like volkswagens
    ok first simple things are...
    50mm inlet manifold (gas flowed)
    drill airbox
    K&N air fliter
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Just a noticable increase...nothing to major
    Ive got a K&N filter on at the moment and I have been offered a chipped computer for a couple of hundred dollars, but I wondering if there are any other alternatives that are a little cheaper.
    Drilled airbox and manifold sound relatively cheap but are they easy to do myself?
    Jun 2006
    Orange NSW
    Drilled airbox can be done with a holesaw. Pretty damn easy. Velly or someone or similar 16v experience should be able to get you some pics.
    The manifold is a straight swap as far as i know, so aslong as you put a new gasket on or don't damage the old one you should be ok.
    200 bucks for a computer sounds reasonable.
    Remember, dude, unless you can make everything yourself and do ALL the work, you've gotta pay to play.
    Quote Originally Posted by alex_stott View Post
    Alex
    Do you mean your car is stock and it is a 16V
    Oct 2006
    sydney
    short term
    fuel pump fuel filter
    plugs leads
    longterm
    cam
    adjust cam gear
    lighten flywheel
    aftermarket fuel comp
    turbo
    sky is the limit $$$$
    Oct 2006
    ive got a spare 50mm intake and gaskets if u wanna get it.
    i thought you can not chip a k-jet?!?!?
    i will get you a pic how to drill an air box, it is pretty simple
    Velly
    '91 2.0 8v GTI
    Jun 2007
    Kjet is mechanical injection, i cant see how you'd chip it either?
    i like volkswagens
