Mk2 Golf GTI indicator fuse blowing?
I was driving home today and half way home my indicators stopped working. I tested it by putting another fuse in and they keep blowing. Does anyone know why this is or how to fix it?
Thanks
Check your Hazard light switch( if it's the one on the steering wheel).
Same thing happened to me and took me a while to work out it was a busted hazard light stitch.
Would buzz instead of blinking and no light would appear on any turn signal.
If it is a hazard light switch let me know cause aim still trying to track one for my mk2!
07 GTI
APR stage II
Thanks for the reply. I don't think that's it because the hazards still work fine. When they first stopped working the green indicator light would come on, but wouldnt tick or flash. Now it just works for a few ticks then blows the fuse.
Sounds like a short somewhere then.
I'd be checking all the turn signal wiring in places like rear hatch, front engine bay- you might have worn through wiring in the loom.
07 GTI
APR stage II
All fixed thank god! Turned out to be a blow bulb in the right side indicator
Wow simple fixes are always the best!
07 GTI
APR stage II
- You may not post replies
- You may not edit your posts
Forum Rules
