Results 1 to 4 of 4
Thread: Mk2 Clutch
    May 2006
    Mk2 Clutch
    Can anyone recommend a good online tutorial for clutch assembly removal and replacement. I've done lots of conventional clutches before but reading the Bentley makes the Golf seem hard. Lots of detailed photos would be good.
    Thanks
    Nov 2005
    Block| -> p-plate -> p-plate cap and big circlip -> clutch disc -> fly wheel.
    Center the clutch disc before tightening the fly wheel.
    Torque to spec and your done.
    Then have fun getting the gear box spline to mat up to the clutch disc centre hole.
    It's not hard at all. Takes a while through to get the drive shafts off and all the other bits and pieces.
    Two-man job is recommended.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
    Golfwise Guest
    If you have done lots of others the Golf one won't be difficult its all common sense and I consider them easy.
    Just do it.
    Camden, Sydney
    just put the clutch on loosely so you can move the disc around. stick your finger or a 12mm long socket in the hole and centre it. Check and tighten. Easy.
Similar Threads
  1. HELP! Clutch pedal stuck all the way in...
    By gman in forum Mk3 Golf & Vento
    Last Post: 24-01-2007, 07:33 AM
  2. CLutch Pedal - Hydro
    By golf3 in forum Mk3 Golf & Vento
    Last Post: 30-06-2006, 07:47 AM
  3. CLUTCH!!!!!! help... 2E series 8v motor
    By 86gti in forum Mk2 Golf & Jetta
    Last Post: 17-04-2006, 06:52 PM
  4. need advice on upgrading to a bigger clutch
    By mollins in forum Mk1 Golf
    Last Post: 09-01-2006, 07:56 AM
  5. Which clutch
    By Gas in forum Mk1 Golf
    Last Post: 03-08-2005, 05:50 PM
