"neatly" round it out so cylinder fits in? then just diy something to hold it in place? got any pics of your problem?
-Thomas
Sent from my SM-G920I using Tapatalk
Hi people,
just a quick one, the original door handle on my car is broken on the inside (lasted 35 years!), I ordered a brand new one (probably made in China) and the new cylinder fits into the old handle but the orignal cylinder from VW does not fit into the new one. Any thoughts for a solution? (I do not want to change all the locks of the car) Officially, I bought the correct product and the Germans don't make them anymore otherwise I'd order the original part
Cheers !
Nick
1985 GolfMk2 CL
-Thomas
'89 VW Golf Mk2 2dr VR6
'96 VW Golf Mk3 2dr 1.8t
'02 VW Transporter SWB
G'day Thomas,
just took a couple of pics; actually the cylinders seem to be exactly the same size - the original one just will not go in any deeper than that. Round it out ? I like your thinkingWill give it a try !
ta
1985 GolfMk2 CL
rounding out the handle has not lead to any result![]()
1985 GolfMk2 CL
damn. find the point where its jamming and then clear it out. you might have to destroy the inner plastic cylinder from the handle to fit it. then glue it in. not sure just throwing out suggestions
no worries! Would be fun to know if the plastic handle could be seperated from the metal component inside; I only need the broken bit replaced but it's reveted in ... maybe I'll ask a locksmith for advice but I reckon it'd be expensive.
1985 GolfMk2 CL
yea. maybe try find a second hand one in AUS.
I've got one lying around somewhere.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
cheers mate, found one already! I'll try to fit in the cylinder and see what happens![]()
1985 GolfMk2 CL
Should be an easy fit. If all else fails pull the new cylinder apart and swap the slides as best you can to suit the profile of your key then file the top of the slides so they fit neatly back into the cylinder.
