Results 1 to 10 of 10
Thread: MK2 broken door handle
    Sep 2006
    Hi people,
    just a quick one, the original door handle on my car is broken on the inside (lasted 35 years!), I ordered a brand new one (probably made in China) and the new cylinder fits into the old handle but the orignal cylinder from VW does not fit into the new one. Any thoughts for a solution? (I do not want to change all the locks of the car) Officially, I bought the correct product and the Germans don't make them anymore otherwise I'd order the original part
    Cheers !
    Nick
    1985 GolfMk2 CL
    Nov 2019
    Tasmania
    "neatly" round it out so cylinder fits in? then just diy something to hold it in place? got any pics of your problem?
    -Thomas
    Sent from my SM-G920I using Tapatalk
    '89 VW Golf Mk2 2dr VR6
    '96 VW Golf Mk3 2dr 1.8t
    '02 VW Transporter SWB
    Sep 2006
    G'day Thomas,
    just took a couple of pics; actually the cylinders seem to be exactly the same size - the original one just will not go in any deeper than that. Round it out ? I like your thinking Will give it a try !
    ta
    Attached Thumbnails Attached Thumbnails MK2 broken door handle-img_19700307_002044-jpg   MK2 broken door handle-img_19700307_001903-jpg
    1985 GolfMk2 CL
    Sep 2006
    rounding out the handle has not lead to any result
    1985 GolfMk2 CL
    Nov 2019
    Tasmania
    damn. find the point where its jamming and then clear it out. you might have to destroy the inner plastic cylinder from the handle to fit it. then glue it in. not sure just throwing out suggestions
    Sep 2006
    no worries! Would be fun to know if the plastic handle could be seperated from the metal component inside; I only need the broken bit replaced but it's reveted in ... maybe I'll ask a locksmith for advice but I reckon it'd be expensive.
    1985 GolfMk2 CL
    Nov 2019
    Tasmania
    yea. maybe try find a second hand one in AUS.
    I've got one lying around somewhere.
    Sep 2006
    cheers mate, found one already! I'll try to fit in the cylinder and see what happens
    1985 GolfMk2 CL
    Should be an easy fit. If all else fails pull the new cylinder apart and swap the slides as best you can to suit the profile of your key then file the top of the slides so they fit neatly back into the cylinder.
