Results 11 to 20 of 23
Thread: mk2 aircon.
    May 2006
    yeah i still might be coming along ...i did just take the car to VAG for service and they are replacing the brakes frnt and back so hopefully pick up tomorro...i am really wanting to come on this cruise.
    i think my air con needs regassing as the NRMA report stated .... how much for that job ?
    Sep 2006
    Banff, Canada
    Antinora, read my thread "A/C Pain thread" in the MK3 section. It will give you some idea of how painful VW A/C fixes can be... But so worth it on days like today (hot as $%^#!!!)
    Has some important reading too regarding upkeep of ur system......
    Cheers!
    John
    Canadian dubs coming to VWwA soon
    May 2006
    thanks for the info Golfer very helpful..im getting the car tomorrow so ill check the air con and see it its there...
    by the way when i put the air con on sometimes the battery light comes on is that signalling i need a new battery ? ??
    syncro Guest
    Could be belt slipping.
    The light indicates alternator not charging.
    Oct 2005
    Dandenong North, Vic
    Quote Originally Posted by Golf Loon
    I suspect the AC systems were fitted here. There are anomalies between the systems on different batches.
    I dont beleive this is true, with what parts, VW or other ? What are the anomalies ?
    Camden, Sydney
    Quote Originally Posted by aussieg60
    different pullies and compressors, that cant be interchanged as the belts dont line up. System is different on 1990 and 1992 car.
    It could just have been messed with, but I am basing this on more than one car.
    syncro Guest
    Maybe 'cause a 92 car is a Golf 3
    May 2006
    Quote Originally Posted by antinora
    This is almost certainly the compressor belt slipping as syncro says. It happens on a wet road when even small amounts of spray get thrown up onto the belt. You need to fit a gravel tray under the pulley to shield the belt. So far as I know VW didn't make one. I have seen a plastic one that was made in Italy (maybe the Italian cars had aircon too). Otherwise you need to make something up yourself or get one made. A panel shop or sheet metal shop is probably the way to get one made.
    Its a real bug on these cars because the demister starts the compressor to force the air through the pollen filter and since you mostly need the demister when you're on a wet road ...
    The demister/compressor story makes me think the aircon cars might have a unique wiring loom too.
    syncro Guest
    Yes, VW do make one. GTI imports were selling them.
    May 2006
    really so i can get this guard from gti imports ? ?
Similar Threads
  1. need aircon kit to fit 1.6 diesel
    By posscakes in forum Diesels
    Last Post: 29-01-2007, 12:49 PM
  2. Dash Mat/ Aircon - 79 Golf GLD
    By Garbon in forum Bodywork/Trim & Detailing
    Last Post: 16-11-2006, 06:23 AM
