Page 9 of 27 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 265
Thread: Mk2 2dr Project Car (1.8t swap)
  1. #81
    Jun 2006
    Hornsby
    Fancy selling that dash
    90 GTI Mk2 1.8t soon to be with GT28rs
  2. #82
    Nov 2019
    Tasmania
    Quote Originally Posted by tommymac View Post
    sounds like you'll have to pm me haha
    Sent from my SM-G965F using Tapatalk
    '89 VW Golf Mk2 2dr VR6
    '96 VW Golf Mk3 2dr 1.8t
    '02 VW Transporter SWB
  3. #83
    Nov 2019
    Tasmania
    Update: 10/07/2021
    The project goes on, VR6 will be moved first, then the mk2. Its a 3 hour trip so mk2 will be done sometime in the month.
  4. #84
    Nov 2019
    Tasmania
    Update: 26/09/2021
    Yep it still goes on. VR6 donor home, engine next, then the mk2 hopefully within the month, then its continuing on with chucking everything back in.
    Spent some time running the wiring through the firewall, took about 50 pictures as I unplugged everything from the fuse box, fed the wires through then plugged back in.
    Fixed up the knee bar mounts. I didn't see the point in making flashy mounts, plus this was already thick steel, so I just welded shut my adjustable mounts (literally welded the bolts in) now that I know where they need to be set to and gave them a lick of paint, they ain't moving!
  5. #85
    Aug 2006
    Melbourne VIC
    Excellent
  6. #86
    Nov 2019
    Tasmania
    Update: 14/10/2021
    Its all done, many 2 hour trips done to bring all parts and cars up. I'm pretty excited about it. Big thanks to my father-in-law for all his help and teaching me heaps to get this far into the project. Now to continue...
    Front suspension is all out again cause I put the wrong sized wheel bearings in (mk2 ones are different to mk3 VR6/Corrado ones) grr.
    I purchased a VibraTechnics VAG800M front engine mount and cut/folded/welded the front engine bracket to suit this, so I can retain the mk2 front crossmember. I had a professional do the welding as this is a crucial structural member. I had no luck trying to source any other crossmembers.
    Drilled holes through strut tower to run brake lines and sensors, the same way the mk3 does.
    Chopped out the little plate for the charcoal cannister and used a mount from my other mk2 parts car to sit that in nicely!
    Slowly running the wiring loom around here and there, possibly looking at needing to extend the ecu wiring loom, but I'm doing everything in my power to avoid this. ECU mounts are setup for right hand side of rain tray, but the VR6 wiring is designed for middle of the rain tray. And its really cramped in the middle in the mk2 so will possibly look at mounting it inside the cab... maybe...
    Always more to come.
    Cheers,
    Thomas
  7. #87
    Feb 2009
    NSW
    I mounted my ecu under the scuttle next to the wiper motor.
    Going to use a mk4 ecu bracket.
    Sent from my SM-G960F using Tapatalk
  8. #88
    Nov 2019
    Tasmania
    Quote Originally Posted by ozgti View Post
    Ended up mounting it against the firewall behind the heater box unit.
  9. #89
    Feb 2009
    NSW
    I thought about that, but decided against it. If the ecu fries itself, you can't get to it too easily.
  10. #90
    Nov 2019
    Tasmania
    For my case I only have two bolts in the bottom, meaning I can easily remove!
