Page 7 of 27 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 265
Thread: Mk2 2dr Project Car (1.8t swap)
  1. #61
    Nov 2019
    Tasmania
    Update: 5/12/2020
    Mk4 rear alloy calipers arrived along with the conversion lines (momentum motorsports from memory?), gave em a nice lick of red paint and they fit good.
    Mounted the ABS unit thingy, had to drill holes and add spacers here and there. Everything got a splash of black and lookin fresh!
    Sent from my SM-G920I using Tapatalk
    '89 VW Golf Mk2 2dr VR6
    '96 VW Golf Mk3 2dr 1.8t
    '02 VW Transporter SWB
  2. #62
    Hiow much does it cost to you?
  3. #63
    Nov 2019
    Tasmania
    Quote Originally Posted by billybones View Post
    80 for the calipers, 100ish for the lines
  4. #64
    Feb 2009
    NSW
    What abs pump is it?
    Sent from my SM-G960F using Tapatalk
  5. #65
    Nov 2019
    Tasmania
    Quote Originally Posted by ozgti View Post
    Its a mk3 VR6 one
  6. #66
    Looking good. This is going to be a sweet drive when done.
  7. #67
    Nov 2019
    Tasmania
    Thanks heaps, im so keen to get it on the road
  8. #68
    Nov 2019
    Tasmania
    Update: 1/1/2021
    Pedal box finally good to go. Had to lengthen the pedals, they needed to be about 70mm lower to have the same height that the mk2 pedals have. The clutch pedal was simply adding in a piece of steel, the brake pedal had a square bracing sort of setup so I had to add a few brackets here and there to maintain its strength. I have stuck with the mk2 accelerator cable as fitting the VR6 one just wasn't going to work (mk2 cable comes out the plenum, the VR6 comes out of passenger side of firewall, too much work to make the VR6 pedal fit). Had to fit a new mount for the accelerator pedal to fit to the cruise control vacuum line. Overall happy with it, hopefully it doesn't foul with anything. Will attempt to fit the mk3 steering column tomorrow. Didn't get many pics, will upload more soon.
    Happy new year everyone,
    Thomas
  9. #69
    Nov 2019
    Tasmania
    Update: 3/1/2021
    Got pedal box in, pedals work a charm!
    Cut the side mounts off the knee bar then put it in by mounting it to where it usually goes on the pedal box... wayyyy too high, like I mean the steering wheel is through the windscreen haha. I attempted welding it in about 100mm lower but I know that doing an approximate lowering will just end up biting me on the bum when none of the venting lines up and so on. So I've left the welding and made some temporary brackets (emphasis on temporary!) which means I can raise/lower and move it forwards/backwards. I'll fit my heater box and a few other things then test fit the dash so I can be sure the knee bar is perfect.
    Spotted a red Mk1 GTD today in Hobart, awesome car, looked immaculate!
  10. #70
    Feb 2009
    NSW
    Interesting... I'll have to check if mine has a knee bar.
