Page 17 of 27 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 265
Thread: Mk2 2dr Project Car (1.8t swap)
  1. #161
    Nov 2019
    Tasmania
    And again! Only some tiny spots this time, but why its happening I just have no idea! I'm ready for a rage quit, who wants to buy it off me?? The amount of labour I've stuck into this thing, the starting price is 50k Mk2 2dr Project Car (1.8t swap)
    Sent from my SM-A135F using Tapatalk
    '89 VW Golf Mk2 2dr VR6
    '96 VW Golf Mk3 2dr 1.8t
    '02 VW Transporter SWB
  2. #162
    Jun 2011
    Without knowing anything about paint.
    Something to do with paint not curing and moisture getting underneath?
  3. #163
    Nov 2019
    Tasmania
    Could be.. I've spoken to a few experts about it and I might not be letting my first coat dry enough (considering I'm spraying in the evening/night when its a bit colder) so that can often cause that reaction. Or I have moisture coming through my air compressor, even though I have a water trap on it. Hopefully I can figure it out.
    EDIT: Came down to the following:
    - Spraying in the evenings was a lot colder, needed to wait longer between coats
    - First coat too heavy
    - Panel needs to be warmed up if spraying in the cold
    - Rainy/humid days added a lot more moisture through the compressor so water trap needed regular draining
  4. #164
    Nov 2019
    Tasmania
    Update: 27/10/2022
    Righto back on track now. The ragequit is over!
    Spoke with a professional who says if the paint blisters like that, you can finely sand it out with 800 grit and then cover it again without needing to reprime. Worked a treat and can finally move on! Might need to colour match this little hotwheels car someone gave me as my next job.
  5. #165
    You fixed it?
    And I was just checking with my bank manager.
  6. #166
    Nov 2019
    Tasmania
    You fixed it?
    Yep fixed!! Haha
  7. #167
    Nov 2019
    Tasmania
    Update: 07/11/2022
    Some minor parts now sprayed like bolts and fuel cap and bonnet arms. Did the underside of the bonnet because I have been spraying all the visible panel surfaces in their correct orientation (ie. standing up or laying down) so after a day of drying I'll be able to lay the bonnet flat to finish sanding and spraying.
    Cheers,
    Thomas
  8. #168
    Damn, I wish I had a garage.
    Mk2 2dr Project Car (1.8t swap)-20221105_115848-jpg
  9. #169
    Nov 2019
    Tasmania
    oh mate you have a nice graveyard there, garage would be good in your case!
  10. #170
    Nov 2019
    Tasmania
    Update: 09/11/2022
    Sprayed bonnet and boot today. Looks crap. Didn't sand well enough and its so obvious in the finish... Strip back and do it again will definitely have to happen. Bugger!
