Results 1 to 5 of 5
Thread: MFA. and other rude words
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    couple of questions.
    is the LCD MFA display sposed to be back lit? cant see it in the dark!...
    and why does my oil temp irraticly go between ---, 99, 65, 100, ---, etc..
    it will go --- (below 50 ) and then all of a sudden upto 90 and all over the place! :-S....also it recons im doing 9.0 MPG..guessing thats an air leak problem though........
    Cheers, Benny
    www.axesent.com.au
    Quote Originally Posted by 86gti
    Yeah should be backlit, I bet one of the bulbs has blown in the clocks.
    It is supposed to read --- below 50. If it is swinging all over check the wiring, the green/black one at the fliter mount. It could be shorting to earth??
    When you have an airleak, the MPG reading climbs up to 99.9, as it monitors vacuum to give it's estimate, when there is no vacuum it assumes you are using no petrol(if only!)
    It could be a bad earth, the one for the clocks is a brown and white on the back right hand cam cover nut. IIRC.
    syncro Guest
    The vacuum hose has a habit of falling off the back of the MFA.
    Quote Originally Posted by syncro
    This is true but the reading goes high not low.
    Apr 2006
    ahhhh. cheers, ill take the clocks out on the weekend and have a peek.
    Cheers, Benny
    www.axesent.com.au
