It's also a warning for the coolant level in the expansion tank. If the tank is full you need a new sensor most likely.
Hey all, I have a '92 5sp digi 4 door Gti, great car, everything works, the only thing that is annoying is that the red temp light in the dash will flash after a bit of stop start city driving, even though the temp needle never goes above 1/2 way, and the MFA oil temp doesn't go past 90.
One mechanic told me to ignore the flashing light, but it has me a bit worried?.
Any opinions appreciated..
S
The temperature sensor and the coolant level plug are completely seperate. have a look to see if the wires going into the top of the bottle are a bit tired. the light will go nuts if it has a bad connection.
also check the level of the bottle regularly. your cooling system might be working a bit harder than it needs to be if it's low.
87' MK2 GTI
13' MK7 TDI
That's great, thanks so much for that! will check it out tomorrow..
Try bridging the wires on the sensor on the radiator bottle and see if that fixes the problem. If so, a new bottle will fix it.
Yeh funny that, my car has the same problem when starting. Usually I head done the road, stop the car and then restart and the light stops flashing. But it is annoying
Ok, seems the light was a warning for low coolant level. looking at the expansion tank (the round type) it's obviously low, below the MIN mark.
I feel like an idiot, but how on earth do I get the cap off to top it up? Is there a trick? Won't budge, and don't want to apply too much force, in case i crack the tank.
Any tips?
there's no trick to it, just gota undo it anti-clockwise. sounds like it hasn't been opened for a while.
