Results 1 to 8 of 8
Thread: MFA Oil temp/temp needle cool, but temp light flashes?
    Jan 2009
    Brisbane QLD
    Hey all, I have a '92 5sp digi 4 door Gti, great car, everything works, the only thing that is annoying is that the red temp light in the dash will flash after a bit of stop start city driving, even though the temp needle never goes above 1/2 way, and the MFA oil temp doesn't go past 90.
    One mechanic told me to ignore the flashing light, but it has me a bit worried?.
    Any opinions appreciated..
    S
    It's also a warning for the coolant level in the expansion tank. If the tank is full you need a new sensor most likely.
    Sep 2007
    The temperature sensor and the coolant level plug are completely seperate. have a look to see if the wires going into the top of the bottle are a bit tired. the light will go nuts if it has a bad connection.
    also check the level of the bottle regularly. your cooling system might be working a bit harder than it needs to be if it's low.
    87' MK2 GTI
    13' MK7 TDI
    Jan 2009
    Brisbane QLD
    Smile
    That's great, thanks so much for that! will check it out tomorrow..
    Camden, Sydney
    Try bridging the wires on the sensor on the radiator bottle and see if that fixes the problem. If so, a new bottle will fix it.
    Jan 2009
    Sydney, New South Wales
    Yeh funny that, my car has the same problem when starting. Usually I head done the road, stop the car and then restart and the light stops flashing. But it is annoying
    Jan 2009
    Brisbane QLD
    Ok, seems the light was a warning for low coolant level. looking at the expansion tank (the round type) it's obviously low, below the MIN mark.
    I feel like an idiot, but how on earth do I get the cap off to top it up? Is there a trick? Won't budge, and don't want to apply too much force, in case i crack the tank.
    Any tips?
    Aug 2005
    Prahran, Vic
    there's no trick to it, just gota undo it anti-clockwise. sounds like it hasn't been opened for a while.
