Results 1 to 10 of 10
Thread: MFA Clocks
    Oct 2005
    Dandenong North, Vic
    I use tooth pics, tried but no luck.
    MK2 GTI G60
    Aug 2007
    Funnily i have to add after i have had a set of clocks that had issue removed from the vehicle ( to fix a temp gauge) i reconnected it of course i cleaned everything with contact cleaner all was well.
    Try removing and cleaning as the good friend before has mentioned they do get gritty.
    Jmac
    Alba European
    Feb 2007
    I cant set my clock at all either, It also only shows time, oil temp, ambi temp and travel time. Speed and economy dont show up, but i dont have a speedo calbe atm.
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2005
    Any body done the below instructions before ? I am interested what others have for (1, 2 in MFA pos 1) and (1, 5 in MFA pos 2)
    MFA pos 1
    1. "117"
    2. "1"
    MFA pos 2
    1. "7401"
    5. "0"
    These are the secret functions of the MFA in case you need to find them later.
    Put your key in (no turn yet). Press and hold the MFA button. Turn key to acc. position. Turn key all the way back. Turn key again to acc. position (no, it's no joke... ). Release the MFA button.
    You are now in the 'secret' MFA operation mode. Below you see a overview of what the codes and numbers mean. Nice gadget: the digital rev counter
    MFA switch on position 1:
    1. Engine code
    2. Land code
    3. Speedometer
    4. Upper rev limitter
    5. Lower rev limitter
    6. Decelaration fuel pressure
    7. Display test
    MFA switch on position 2:
    1. Test programm of programmed bytes
    2. G60 pressure meter
    3. Digital rev counter
    4. Fuel usage (like normal)
    5. Signal from speedo sensor
    6. Oil temperature (like default)
    7. Ambient temperature (like default)
    The codes given below are for G60 (see MFA2-2). But they also work for 8v and 16v (without the boost pressure off course...) MFA menu will go back to deafult when you turn to key back and turn it to acc. mode again (without pressing the MFA button off course).
    MK2 GTI G60
    That's handy with a G60 to check the boost pressure if you don't have a boost gauge.
    The G60 clocks have a different pressure sensor to the std digifant GTI clocks.
