Results 1 to 8 of 8
Thread: lowering springs
    Dec 2008
    Bentleigh, Melbourne
    lowering springs
    lookin at gettin some lowering springs... standard ride height for a valver i think is 333mm (10 mm less than 8v).
    i would like it to be around 300mm.
    having a look eibach pro kit lowering springs, but it says 16v and diesels in the same section.. both are -20mm, but the diesels oem ride height was 360mm.. doesn't make sense, which one is it???
    it also says the g60, 8v's have different springs.. how are they different???
    Eibach / Pro Kit Lowering Springs / Volkswagen Golf Mk2 83>91 / Euro Performance Car Parts
    also any other suggestions for springs??
    cheers
    Jul 2005
    Newcastle, NSW
    Follow Benoughs lead and get H&R cup kit.
    http://www.vwwatercooled.org.au/f46/...tml#post637942
    Apr 2008
    x2
    I got them landed for $700
    Gold Coast
    It doesn't really matter what the original ride height was if they lower by 20mm, ie 16v will drop to 313mm whereas the deisel will drop to 340mm. I think they are recommended for different cars depending on spring rate rather than ride height.
    As mentioned if you are going to get lowering springs you might as well replace the dampers too, get a full kit.
    Dec 2008
    thanks walshy!! i feel so dumb not thinking of that.
    might be a good idea for a new kit..
    i do some research, thanks for the feedback
    Gold Coast
    Quote Originally Posted by Stiggy_21 View Post
    No worries mate, no such thing as a dumb question if you don't know the answer
    Aug 2006
    Melbourne VIC
    As said by other a cup kit (springs and shocks) will do wounders to your ride.
    Also dont forget to replace your strut top mounts (About $80 for the pair) as these do get flogged out over time.
    Dec 2008
    thanks for the info waterboy.
    been emailing a few places to see what they can do for me
    also
    got a birth certificate today
