That system should like most others have a residual pressure, which shold be at least 1 bar which is 14.5 psi after 20 mins. Fuel pressure drop is at the injectors, cold start injector, fuel pump check valve ( which is VERY common) or fuel pressure reg.Of course a leaky fuel line would also cause a pressure drop. Quick sanity check is to run the car with fuel pressure gauge then shut it off, immediatly clamp the supply line and watch the pressure , if it drops right away its engine side, if it stays good its pump side, in which case i would be checking the check valve
Quick test and saves a bit of time , at least you will pinpoint if its leaking at the engine or the rear in under 20 mins
Jmac
Alba European
