Exhaust fixed, nice to have a sweet exhaust note back again.
Also today received in the mail my new Heater matrix and wiper/indicator switch gear- purchased from VVW member Lucky13, thanks mate!
Started this afternoon to install the switch gear ,removed the steering wheel and old switches and then ran out of light.
So tomorrow morning will reassemble.
07 GTI
APR stage II
Another delivery again today!
My new radiator panel arrived today( yes that's right " NEW" OEM stock)
Thanks to Eurocarparts in Sydney.
Now all I need to fix my front end is a bonnet and some main beam headlights.
Still un sure whether to just get one OEM Hella one or bite the bullet and go for some black tinted ones.
Sure will be nice to have a straight grill and front end!!
Also stayed up late last night and installed the gear shift repair kit ( approx $25 on ebay from the UK).
Major difference in the shift feel. I still need to make some minor adjustments as 5th is a right bastard to shift into and there is plenty of space left on the 1-2 side.
All up took 2 hrs- hardest part is sliding the bracket back on to the shifter column!!
Helped having the wifey pull the stick all the way back.
Um, don't know how else to say it, but anyone that has done it ( change the shift bushings) knows what I mean.
07 GTI
APR stage II
I still think it would have made a good nerf gun.
Glad to see it's slowly getting there.
You won't regret OEM Hella's (they fit well and look the part), but I'd be curious to see how tinted looked...
Playing around with the shifter is rewarding!
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Cheers Ryan and Paul!
It's you guys that have inspired me to keep the project rolling
Yeah, I'm still deciding on the headlights.
The left hand one on now is a repair job using a beetle lens ( yes it fits on but only just and took some modifications of the bent bracket/headlight support backing.
The bracket that supports the shift column mysteriously came loose and I lost reverse last night, but seems ok again after tightening them up- I could have sworn I did them up tight but getting in there with a socket wrench was fun.
Hopefully this weekend I can divert my attention to this:
07 GTI
APR stage II
What happened to the ovlov?
HAHAHA
