You need to check that the earth points are connected correctly. It looks like something is using the LHS indicator circuit as an earth.
Hey all,
QQ, what would be causing this? All passenger side indicators are staying on even thought the indicator stalk is in neutral position.
NB: Some electrical wiring was done to hook up my radiator fans to the fuse box.
I had this issue too, problem ended up being a fused/shorted wire where the indicator positive lead had touched the negative (happens when the bumper falls off!)
Minor rewire required of said wire, but be careful who does this for you, I ended up losing the water protector under the grill part of the bonnet.
WronGTIme!
Thnks KBVW!
