Originally Posted by
ozgti
Cancel that. Injectors are dry. But the plugs smell rich. Odd. Pulled the injector out into a spray can lid. Nothing. No dribble spray or anything. I have a mk1 head I'm going to try, but I don't like my chances!
So you did this while moving the air plate up,with the fuel pump relay removed and a bypass switch operational ?
Also check to see if the cold start injector is squirting from the injector tip when first cranking it over.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
