Results 1 to 10 of 20
Thread: Kjet GTi Doesn't want to start.
    Feb 2009
    NSW
    Checked fuel/spark all there.
    Cranked the engine with my hand on the venturi plate and it moves up, then back down.
    Sometimes it will start this way... Other times I have to let it sit and then it still won't start.
    If there is too much fuel getting to the metering head, will it just go back the return line or will it flood the engine? (replaced all the thin line with 8mm Fuel line to the banjos (Last ditch effort to get this bloody thing going before I swap the engine out or do something to it!)
    Help as I need the car after NYE!!
    Jun 2006
    Orange NSW
    I have had similar issues with my mk2 before swapping to aftermarket EFI.
    Mine didn't like to start very well cold though once it was hot it required cranking the engine for 30 seconds or more with closed throttle to clear excess fuel from the cylinders. This was due to a worn metering head bypassing and allowing the fuel to the injectors when the engine was off.
    I found the cause by sticking all the injectors in glass jars and checking the flow from them whilst cranking the engine, once i stopped cranking they kept spraying fuel until the pressure dropped.
    The metering head has a pressure relief valve in it to maintain a constant fuel pressure and flow. Excess fuel is returned back to tank.
    You could do the same test on yours.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Feb 2009
    NSW
    Cancel that. Injectors are dry. But the plugs smell rich. Odd. Pulled the injector out into a spray can lid. Nothing. No dribble spray or anything. I have a mk1 head I'm going to try, but I don't like my chances!
    Feb 2009
    NSW
    No joy. =(
    Perth. WA
    Quote Originally Posted by ozgti View Post
    So you did this while moving the air plate up,with the fuel pump relay removed and a bypass switch operational ?
    Also check to see if the cold start injector is squirting from the injector tip when first cranking it over.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Feb 2009
    NSW
    Quote Originally Posted by roccodingo View Post
    I used to be able to start it by cranking it and moving the plate. I can feel the plate suck upwards at the start then it pretty much bounces in time with the cylinders firing I think.
    When cranking, nothing is coming out of the metering head when I removed one of the fuel lines.
    I'll check tomorrow.. I hate smelling of fuel!
    Jul 2005
    Newcastle, NSW
    I'd do some detailed reading. Kjet is a fiddle but if tuned right bombproof.
    Bentley Manual: VW GTi, Golf, Jetta 1985-1992
    Feb 2009
    NSW
    I know. I want to keep it but I think bike carbs are calling!
    Feb 2009
    NSW
    If the warm up reg is faulty, will that stop the fuel flow?
    Going to try the injector test this afternoon
    Jan 2012
    ADELAIDE CITY
    Stupid question.... but you do have fuel pressure at the metering head don't you?
    I remember undoing those bloody banjo's on my old kjetter and getting f*cking fuel in my eyes!! I was like --> then like
