Engine does not start/starts hard when warm
Symptom: Engine does not start/starts hard when warm
Leaks in air intake system (false air) Check air system for leaks
Sensor plate and/or plunger not moving freely Check for free movement
Air flow sensor plate stop incorrectly set Check and reset
Electric fuel pump not operating Check pump fuse, pump relay and pump
"Warm" control pressure too high Test pressure
Fuel system leakage Inspect fuel system for leaks
Injector leaking, opening pressure low Check injectors on tester
Injected fuel quantities unequal Check for equal fuel quantities
Basic idle setting incorrect Check and adjust CO level
Irregular idle during warm-up
Auxiliary air valve does not open Check valve for correct function
Cold start valve leaking Check cold start valve
"Cold" control pressure outside tolerance Test pressure
Lambda control system not functioning correctly Check Lambda control system
Irregular idle with warm engine
"Warm" control pressure too low Test pressure
*Lambda control system not functioning correctly Check Lambda control system (KE ONLY)
Engine will not accelerate, backfires
*Lambda control system not functioning correctly Check Lambda control system (KE only)
Backfires under load
Primary system pressure out of tolerance Test pressure and adjust with shim
Poor Performance
Symptom: Poor Performance
You mistakenly purchased a 1.3 litre golf or a honda civic.
Leaks in air intake system (false air)- Check air system for leaks
Sensor plate and/or plunger not moving freely -Check for free movement
"Warm" control pressure too high -Test pressure
"Warm" control pressure too low -Test pressure
Primary system pressure out of tolerance- Test pressure and adjust with shim
Injected fuel quantities unequal- Check for equal fuel quantities
Throttle butterfly does not open completely- Check butterfly and stops in throttle venturi
banana in the exhaust
Engine runs on
Fuel consumption too high
**Lambda control system not functioning correctly Check Lambda control system (KE again)
Driving performance unsatisfactory
Excessive fuel delivery to control circuit Check fuel delivery
vehicle has Holden badges fitted
CO concentration at idle too high
Idle speed cannot be adjusted
Auxiliary air valve does not close Check valve for correction function
and a quite common problem.
Engine starts but dies staright away.
That pretty much covers the whole system from tank to injectors.
But there is still quite allot of info if you are interested in the system. I got very interested in it after messing around trying to fix problems.
It is actually a good system if you look after it and maintain it correctly as it's getting fairly old now.
I will make another section soon on modifications.
Thankyou for all the replys!!!
If any one wants to add to this please feel free!!
Cheers.
- You may not post replies
- You may not edit your posts
Forum Rules
