Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: K-Jet info and testing.
  1. #31
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    Engine does not start/starts hard when warm
    Symptom: Engine does not start/starts hard when warm
    Leaks in air intake system (false air) Check air system for leaks
    Sensor plate and/or plunger not moving freely Check for free movement
    Air flow sensor plate stop incorrectly set Check and reset
    Electric fuel pump not operating Check pump fuse, pump relay and pump
    "Warm" control pressure too high Test pressure
    Fuel system leakage Inspect fuel system for leaks
    Injector leaking, opening pressure low Check injectors on tester
    Injected fuel quantities unequal Check for equal fuel quantities
    Basic idle setting incorrect Check and adjust CO level
    Cheers, Benny
    www.axesent.com.au
  2. #32
    Apr 2006
    Irregular idle during warm-up
    Auxiliary air valve does not open Check valve for correct function
    Cold start valve leaking Check cold start valve
    "Cold" control pressure outside tolerance Test pressure
    Lambda control system not functioning correctly Check Lambda control system
    Cheers, Benny
    www.axesent.com.au
  3. #33
    Apr 2006
    Irregular idle with warm engine
    "Warm" control pressure too low Test pressure
    *Lambda control system not functioning correctly Check Lambda control system (KE ONLY)
    Cheers, Benny
    www.axesent.com.au
  4. #34
    Apr 2006
    Engine will not accelerate, backfires
    *Lambda control system not functioning correctly Check Lambda control system (KE only)
    Cheers, Benny
    www.axesent.com.au
  5. #35
    Apr 2006
    Backfires under load
    Primary system pressure out of tolerance Test pressure and adjust with shim
    Cheers, Benny
    www.axesent.com.au
  6. #36
    Apr 2006
    Poor Performance
    Symptom: Poor Performance
    You mistakenly purchased a 1.3 litre golf or a honda civic.
    Leaks in air intake system (false air)- Check air system for leaks
    Sensor plate and/or plunger not moving freely -Check for free movement
    "Warm" control pressure too high -Test pressure
    "Warm" control pressure too low -Test pressure
    Primary system pressure out of tolerance- Test pressure and adjust with shim
    Injected fuel quantities unequal- Check for equal fuel quantities
    Throttle butterfly does not open completely- Check butterfly and stops in throttle venturi
    banana in the exhaust
    Cheers, Benny
    www.axesent.com.au
  7. #37
    Apr 2006
    Engine runs on
    Fuel consumption too high
    **Lambda control system not functioning correctly Check Lambda control system (KE again)
    Driving performance unsatisfactory
    Excessive fuel delivery to control circuit Check fuel delivery
    vehicle has Holden badges fitted
    Cheers, Benny
    www.axesent.com.au
  8. #38
    Apr 2006
    CO concentration at idle too high
    Cheers, Benny
    www.axesent.com.au
  9. #39
    Apr 2006
    Idle speed cannot be adjusted
    Auxiliary air valve does not close Check valve for correction function
    and a quite common problem.
    Engine starts but dies staright away.
    Cheers, Benny
    www.axesent.com.au
  10. #40
    Apr 2006
    That pretty much covers the whole system from tank to injectors.
    But there is still quite allot of info if you are interested in the system. I got very interested in it after messing around trying to fix problems.
    It is actually a good system if you look after it and maintain it correctly as it's getting fairly old now.
    I will make another section soon on modifications.
    Thankyou for all the replys!!!
    If any one wants to add to this please feel free!!
    Cheers.
    Cheers, Benny
    www.axesent.com.au
