Great little write up, don't own a Kjet MK2 yet but I'll deffinantly favourite this.
Could a mod sticky this?
top job!!!
keep up the great work
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
cheers peoples, yeah shure helps if you do own a k-jet. Because most mechanics run and hide, or spend tonnes of your money "trying" to find the problem. I'll add some more soon.
Cheers, Benny
www.axesent.com.au
Great info! Very handy..
An LPG safety relay is also a tachometric relay and performs the same priming function. About $30 from an LPG fitter or auto electrician.
GAP sell the stock ones for about $25. I keep one spare forthe race car as it's a saftey requirement that the fuel pump shuts off if the motor stops running.
http://www.germanautoparts.com/Volks...ectrical/170/1
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Thanks Benny, I'm bookmarking this thread. Next time you're down Canberra way I'm shouting you a beer or 4.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
OK, so I've got this issue with my valver: it struggles to start when stone cold (after sitting in the garage overnight), when it does though, it idles smoothly, no issues whatsoever until I take it on the road and occasionally (after only about a 1-2 minute drive, when still cold) it will stall (when coming to a stop/roundabout)? It's not the ISV, as I have given it a very good clean and it is working fine - again the idle is very stable.
I'm thinking it could be the cold start valve (but then after starting and idling ok for a minute or so could it stall because of a faulty CSV?) Doesn't the CSV only assist in starting a cold engine and then become irrelevant once the engine has started?
Could it be the warm-up regulator? Is there anything else that controls the amount of injected fuel during warm-up? I'm thinking the engine is not getting enough fuel when it's cold. Mind you, it runs perfectly fine when warm/hot - starts first time every time, starter motor only needs to turn once and idles very smoothly - it never stalls when warm/hot.
Where is the warm-up regulator located?
Can anyone help, please?
Cheers,
Dom
- Mk2 Golf GTI 16v, 2-door, Tornado Rot, BBS RS, 1988 - SOLD
- E30 325i Coupe, Manual, Alpinweiss
- E30 325i Touring, Manual, Diamantschwarz x 2
- On the lookout for another E30 325i Coupe, Manual (red would be nice)...
WUR is the thing with 2 hoses going to it on the front f the engine block, just below and to the left of the upper hose outlet.
I got a new relay, and I can hear the main pump prime twice. But still has the same symptoms. stutters at anything above 2k. Would I be correct in saying that this is the main pump dying/dead? It's noisey as hell too!
Parts4vws.com and Parts4Audis.com - Fuel Pump Relay
relay there. the ones I got were a different brand and made in Germany. "Kracker" was the brand I think.
My original relay didn't prime when the key was turned on, the new one I got primes 2 times.
Cheers, Benny
www.axesent.com.au
