Main Pump
In the MK2, the main pump is located in the smaller tank (reservoir)....
This pump is a roller cell pump, with the fuel entering the pump and being compressed by rotating cells that force it through the pump at high pressure. It will apparently pump upto 8 bar (120 psi) with a delivery rate around 4 to 5 litres per minute .....the system relies on pressure to run well....so this is one of the Main parts of the system.
Within the pump is a pressure relief valve that lifts off its seat at about 8 bar to stop the pressure incase the filter, fuel lines or other things become obstructed. The other end of the pump (out) is where the non-return valve is.... When the voltage to the pump is removed it closes the return and maintains pressure within the system... we get to that later
The operating pressure in the system is approximately 5 bar (75 psi) and at this pressure the current drawn on the pump is around 5 to 8 amps.
Apparently the inside of the pump (armature) will spark etc......!!!! sounds bad when fuel is passing in there...
But absence of Oxygen means no explosion! hahahaha....
To test your deliver rate of the main pump get under the bonnet and find the fuel return hose....
this hose returnes the fuel back to the tank that has been unused.
the K-jet system doesn't Pulse fuel into the manifold like an EFI set up....it is always injecting so there is always fuel being recurculated..
plug the main pump back in where you unpluged it to test the lift pump.......
the return line on mk2 is just infront of the firewall on the driver side (UK car)...
this test also relies on the voltage at the main pump..so low voltage at the pump means a bit less delivery...
.....see what sort of voltage you have at the pump between 10-12v is usuall...
now run the return line into a measuring cup (mid sized) from memory mine held about 17oz.
run the pumps from the switch for 30 sec and turn off.
at 10v you should have around 350-380cm3
at 11v you should have around 500-520cm3
at 12v you should have around 650-670cm3
BTW cm3 is also cc ..........1000cc (cm3) = 1lt etc.
this is where i found a problem with my MK2 about 5 years ago.
all my pressure tests were fine, but my delivery from the main pump was less than half what it should have been...
was hard to start when warm, would miss and carry on allot, and eventualy wouldnt start at all...
new pump had it running better than ever
If you plan on getting more indepth than this i would urge you to get a bently manual... (I got mine from Pitstop book shop in WA)
also please be careful when playing around with fuel, especially at high pressure!!
