Still seeing a few people with issues on starting, starvation of fuel in corners etc etc.
All the good and scary things of K-jet. I'm sitting in a Tokyo Appartment with nothing to do so I'll post up some of the tests, tips and tricks with trouble shooting K-Jet Problems
OK! K-Jet (CIS) is not a sware word!
in this thread im going to share some info on the K-jet system.
If yo have any more to add please feel free.
cool vid on the system working here
The first glance at a mechanical Injection system can be a daunting thing!
But with good knowledge of EFI systems etc I took a deep breath and drown myself in all the information i could find on the k-jet Mechanical system. Books, Manuals, Web sites etc.for over 5 years.... and now for some silly reason the K-jet system is something I love and have had many years playing with and doing mods to.
It seems it isnt as bad as you would first think! with a few basic tools and a willingness to learn you can do most of the work yourself (I would sugest anything to do with the fuel distributor/AF meter be done by someone who knows exactly what they are doing tho!!)
Its all pretty simple when you break down the system into Main Parts. from the tank to the injector.
-Fuel Tank
-Fuel Pump
-Pump Relay
-Fuel Accumulator
-Fuel Filter
-System pressure (primary pressure regulator)
-Airflow sensor/Meter
-Fuel Distributor
-Warm up Regulator
-Cold start injector
-Aux Air Valve
-Injectors
the main points you will need to break faults into are.
-Fuel Supply
-Air flow Measurement
-Fuel Metering
In this thread i will go over the basics of each section.
when you know what each part does, it makes it less of a head ache to understand.
THE TANK.....
We all know what that is....Its the part of our car that we spend the most money on!
In Most cases in K-Jet (CIS) cars the tank is a sealed unit. it allows the natural gassing of petrol to help delivery to the pump by slightly pressurising the tank. sometimes when u remove the cap you will hear the pressure pass out (especialy on a hot day).
im led to believe some of the older systems were vented, but on later models this isnt the case.
The MK2 runs a "lift pump"... this supplies fuel to another small tank found under the car ... in it is the Main pump that supplies the rest of the system. (basicly under the driver side rear seat)....
This is sort of like a surge tank set up to always keep pressure to the pump when you are conering, braking accelerating ect.
PUMPS.....
Pick up Pump, Lift pump, transfer pump or what ever you wish to call it is the first pump to pick up the fuel in the tank.
Make shure this is working well...If this doesn't work well it will starve the Main pump and you will find yourself replacing 2 Pumps!!
(been there done that)
Testing this pump is fairly simple.
Find your Fuel pump relay.... This was no where near where it said it was in the bently manual so im guessing the US versions differ a bit from the European vehicles. My relay was stamped number "62" and was in the top row of relays on the left.
when you get it out you will see 2 large pins and 2 or 3 small pins (cant remember how many small ones..but they dont matter at this stage)
where the 2 lage pins fit into the relay holder is where we are looking
Grab a switch (toggle ones are best - 2 pole) solder wires to the poles and fit large spade bits on the end of the wires.
make shure the switch is off and plug the spades into the 2 LARGE slots in the relay holder.
dont turn it on yet!!!!!!(if its not off you will hear the pumps fire up when you plug it in, no harm done, just turn it off quick)
Now, dissconnect the warm up regulator!! you will see this on the front side of the engine block, just unplugs...
have a look under the car driver side just under where the back seat is....
you will see the main pump with a plug going into the top of it. It a std type plug that can be removed by pushing the wire clip at the top and sliding it off.
once you have done that we will find the Lift pump.
take up the carpet in the boot well. to the right and up a little from the spare wheel well you will see a plate with 3 screws in it.
undo them and take the plate off to reveal the top of the pump and Fuel guage sender.you will see 2 hoses, both with arrows.
one points in (returned fuel from system) one pointing out...one pointing out is the one you want...
Take the hose off it, and find another bit of hose that will fit over the outlet.
now we are ready to testthe delivery rate. Grab a mesuring cup that will hold at least 500cc and get ready to let the fuel go into it.
get some one on the switch ( ill do it for a tinnie or 2)...
flick the switch and leave on for 10 seconds
you should get at least 400cc / 13 and a half Oz. into the cup...
If you have..thats good news..if not......................
Replace it before the main pump decides to retire.
Try to use Genuine Bosch parts where ever you can . I am running a high pressure Carter Pump in mine and it seems to work fine although a bit more noise than the Bosch product.
well thats step one of a basic Check up and General over view of the Fuel Tank Section and Transfer pump.
