Page 18 of 28 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 280
Thread: Jay Jays Mk2 Project
  1. #171
    Sep 2007
    well it's been ages since anything has happened.
    i'm on uni break now so time isn't really of any essence.
    megasquirt i've been kinda slack with, (read non existant) so i took another plunge of sorts.
    the whole idea with megasquirt was so that it could idle with throttle bodies, but hopefully with these it might do the exact same thing, only mechanically.
    it needs a couple of linkage pieces but after that.
    edit: i think i'm going to have to also play with the distributor. but that'll be a bit later
    87' MK2 GTI
    13' MK7 TDI
  2. #172
    Jan 2007
    They look awesome Jay, you finally get the fueling you've needed all this time!!!
  3. #173
    wohooooo for carbs
  4. #174
    are you going to run the carbs as throttle bodies??? if you are why didnt you just get some bike iTB instead?
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  5. #175
    Quote Originally Posted by velly_16v_cab View Post
    that doesn't make any sense!
    he's running carbs, cutting out all the electronic bs
  6. #176
    Sep 2007
    hahaha. well actually i'm not getting rid of electronic bs, but tired component missing fanagled k-jet bs.
    i'm running the carbs as carbs and modifiying the distributor for more advance.
    then exhaust, then new shell. hahahaha
    87' MK2 GTI
    13' MK7 TDI
  7. #177
    Quote Originally Posted by GoLfMan View Post
    i have seen in the past people machining out a carb to fit an injector to run it as an ITB...because he said about running MS i thought that was what he was doing lol
    all sorted now, back to the show
    Velly
    '91 2.0 8v GTI
  8. #178
    Sep 2007
    hahaha. i just found out the most interesting fact..
    the guy at techtonics tuning who i ordered parts from was colin.
    apparently in the mid 90s, he ran a drag rabbit with and EV head on a 2.0 PL block with k-jet. the thing was stripped out to the max, like less than 700kg, but he was pulling high 12s on the 1/4 mile. holy jesus!!
    i feel like less of a man for not sticking with k-jet now.
    87' MK2 GTI
    13' MK7 TDI
  9. #179
    k-jet can work well, plenty of 2.0 16v's running back in the up between 180-200 bhp (@fly)
    Velly
    '91 2.0 8v GTI
  10. #180
    x2 K-Jet when tuned right is a fantastic system Problem is getting parts for it over here
