Page 16 of 28 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 280
Thread: Jay Jays Mk2 Project
  1. #151
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by jayjay View Post
    hahaha, well i dunno. the pinging gets pretty intenese.
    mm, i have no doubt the engine will out last the car...
    Pinging will have very little to do with cam timing .
    I re-read the whole thread . There is no concrete data for the engine ???
    Pistons have been flycut and its running a 288 cam . Thats it ????
    If your gonna build a high comp engine your gonna have all the data on file , otherwise its a time bomb so:
    Whats the deck height with the piston at tdc ?
    head gasket thickness?
    Head CC ?
    CFM flow of inlet/exhaust ports , what valve size , spring size ?
    Is this the cam : http://www.mk3love.com/reviews/engin...ulic-camshaft/
    and lastly whats the AFR on WOT ?
    Bug_racer supports the rebellion of the euro revolution
  2. #152
    Sep 2007
    ok ok ok . i have no concreted data for this motor. it's going to explode.
    wtf are you going to do with those numbers? tell me the exact theoretical horsepower and the exact motor characteristics? how about i cut the block in half so you can do a metallurgical analysis.
    /thread.
    87' MK2 GTI
    13' MK7 TDI
  3. #153
    Sounds like bug racer is just trying to avoid you blowing up a wholehearted project!
    And its also good knowledge to know whats under your hood at the end of the day!
    keep away from e10 haha!
  4. #154
    Jun 2006
    Orange NSW
    I would actually suggest running E10 if you can get some good stuff. Ethanol burns slower and cooler than petrol and can slow and control your flame speed and lower combustion temps.
    /thread.
    More cam duration and overlap equals more cooling of the combustion chamber and also lowers your dynamic comp ratio. So you can run more comp the bigger the cam you run.. Basically
    AFR he wants to know because a lean condition can cause an overheated combustion chamber/ piston crown and cause detonation (pinging).
    Deck height determines how tight your squish is. Too tight of a squish can cause detonation on the edge of the bowl.
    The *Ping* sound you hear when detonation occurs is 2 separate flame fronts crashing into eachother, causing a shock. One flame front is from a detonation point, the other the spark plug.
    Detonation can do anything from burn pistons to crack rods. If it's pinging its brain out.. Don't drive the bloody thing until you get it sorted.
  5. #155
    Nov 2008
    Sydney, Macquarie Park
    impressions
    jayjay took me for a drive a couple of days ago...and that thing is insane!!! he didn't take past 5 yet, but even then i was holding onto the seat ****ting myself haha i reckon after a good tune it will easily rip my bora
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
  6. #156
    Play with the cam gear to findout where you want the power band then get it on the rollers to sort the timing/fuelling
  7. #157
    Camden, Sydney
    Kjet is the devils spawn, especially when coupled with ratty wiring of an aged, messed with Mk2.
    Thats all I`m saying.
  8. #158
    Camden, Sydney
    Today involved an expensive KJet Fuel Pump Relay and a quick road tune.
    No more Pinging and a good basic setting. Woooooah is all I can say.
    I`m sure Jay will chime in with some input.
  9. #159
    Aug 2007
    What was the go with the relay?????? Kjet is the bomb when its right, and BAD when its bad i personally like it. Really keen to hear the diagnosis on the relay though.
    Good to hear the pinging is gone
    Jmac
    Alba European
  10. #160
    Camden, Sydney
    The car never had a relay, just lots of spliced wires from a sucession of owners.
    Beau built a new loom for the fuel pump relay and then was let down by all the relays being broken and overheating.
    New relay $75! And bingo car starts and pump is controlled by relay again.
    Quick road tune by me and its a bit of a beast
